It is currently Tue Sep 16, 2025 10:28 am
PostPosted: Sat Sep 03, 2022 5:06 pm
First name: Thomas
Last Name: T
Any recommendations for a power tool that can sand thin enough to make 0.20 veneers?
I have a Supermax drum sander, but it can only get down to about 0.040 before it makes contact with the table. I could stack the veneer on another piece of wood to get it down thinner, but then I wonder about consistent thickness along the entire piece.
PostPosted: Sat Sep 03, 2022 6:11 pm
I've made .020 veneer using a Wagner Safety planer, but I would not recommend it if you don't need to. A key word in considering any method is 'reliable'. 'Safe' is another...
If what you're looking for is strips for inlay in rosettes and purfling, those can be made with a draw scraper from thicker stock. You can go to .008" that way, and much thinner isn't much use anyway. Plan on more waste as you get thinner.
Strad et all apparently used a plane set up to make a heavy cut to make purfling strips. Wet the wood surface so that the chip breaker won't do it's job.
PostPosted: Sat Sep 03, 2022 6:43 pm
Hi Thomas,
What type of veneer are you trying to make? I might have an odd piece or two I can send you for the price of the postage.
If you are set on making your own the way to do that is get a piece of MDF and run it through the supermax until it is sanding the entire surface, and then keeping it in that orientation when running it through, lightly spray glue the piece you want to turn into veneer onto the MDF and sand it down until you reach the desired thickness. To remove the veneer use lacquer thinner to lift the edge and while lifting the edge mist lacquer thinner (or pour it) between the MDF and veneer to remove the veneer from the MDF backer board.
If you have a small spray gun, you will be cleaning your gun while removing the veneer. WIN-WIN! bliss
These users thanked the author Clay S. for the post: guitarmaker78 (Sat Sep 03, 2022 9:07 pm)
PostPosted: Sat Sep 03, 2022 7:35 pm
What Clay said!
PostPosted: Sat Sep 03, 2022 7:52 pm
I have a grizzly 18 in thikness sander
that works very well
PostPosted: Sat Sep 03, 2022 8:09 pm
First name: Brad
Last Name: Combs
I’ve been using a sled as well and using the masking tape and CA approach to hold it to the sled. It works really well, just make sure to use the wider mask g tape and burnish it a bit to make sure both sides are stuck down. Stays perfectly flat and easy to separate.
PostPosted: Sat Sep 03, 2022 9:08 pm
First name: Thomas
Last Name: T
Clay S. wrote:
Hi Thomas,
Thanks, Clay. I didn’t think about surfacing the mdf first.
PostPosted: Sat Sep 03, 2022 9:23 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I make .6mm veneers on my performax22/44 easily. Just get a piece of wood 3/4” thick or so (or mdf), sand it flat. Then, spray glue some 220 paper to that. Then, using 80-100 grit paper on drum, sand ur veneer. Reverse direction for consistency. Light passes. Easy peasy.
PostPosted: Sat Sep 03, 2022 9:27 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Added thought. If you need a lot of veneer (I use a lot), consider this site: https://www.veneersupplies.com/categori ... d__Veneer/. They have great stuff. Love their ebony for sure.
PostPosted: Sat Sep 03, 2022 10:02 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
Yeah, I buy it instead of making it. You can get some great stuff; natural wood or dyed veneers.
These users thanked the author doncaparker for the post: Mike OMelia (Sat Sep 03, 2022 10:47 pm)
Users browsing this forum: Bing [Bot], Colin North, roby and 20 guests
